Hello!
I am trying to configure my mastercam lathe 9.1
I cant get it set up correctly. I would like the tool on the right side of the part (like our vtl)
Any help would be great!
-Grant
Hello!
-Grant
Check this thread: http://www.cnczone.com/forums/master...the_tools.html
Its been a while since I was in 9.1 but I remeber that there were three settings that affected how the tool appeared for a VTL. Two were in the tool desciption page - orientation and CW/CCW I believe. And the third was the 'reverse' on that same page.
Make sure you come out of that page and look at what the main screen shows the tool as, because it was not intuitive from the choices there in the tool page. If there are three parameters and two setting for each then there are 3 to the power of 2 or nine combinations if I remember correctly. Make a table and make sure you try all nine.
Good luck
