What's the most accurate switch/sensor when it comes to repeatability?
Background...
I want to build a tool Z height sensor. I don't want to use the electrical contact type (tool completes the circuit to ground). I want it to be either a mechanical switch, or optical or other proximity sensor.
It will be a plunger type design, either hitting a mechanical switch, or moving past an optical sensor (reflective, or slot), or an inductive or capacitive sensor.
(I also plan on putting a limit switch at the bottom of the travel to stop the system - I have broken many expensive tools because of touch off mistakes).
I don't know what repeatability I need to aim for. I'm thinking 0.01mm or better.
Searching through digikey, I can't find much information on repeatability of optical sensors. This one, the omron EE-SX670, (datasheet here http://www.ia.omron.com/data_pdf/dat...eet_csm483.pdf) has a graph on page 4, "Repeated Sensing Position Characteristics" but I don't understand what each of the deltas represents. 0.002mm repeatability looks good, but 0.04mm is a bit much.
Digikey also has a precision limit switch, also an omrom D5A Series, (http://www.ia.omron.com/data_pdf/dat...eet_csm591.pdf) which has a repeatability of 0.001mm, but is $198 - way too much.
I've seen the DIY home/limit switch thread on this forum, but reading about the hysteresis of the magnets makes me question the accuracy.
Any thoughts?
Frank
