585,930 active members*
3,967 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Need break out board suggestions
    Oct 2009
    7
    Hi, I have a CNC Shark Pro with a Xylotex 3525 3 axis board and an ncPod. The current set-up isn't Mach 3 friendly even with the firmware and driver changes and I'm wanting to get away from the ncPod altogether and put a break out board in it's place, which should add quite a bit of attachment capability and allow me to run my digitizing probe, add an E-Stop, a jog controller, etc. The Xylotex has a DB25 connector for input so I would need a break out with DB25 for interfacing with my computer and output to the Xylotex (DB25 on both ends, essentially).
    Could someone make a low cost suggestion? I recently lost my job and trying to make a few bucks on the side (and possibly go fulltime) with the machine. I've seen the CNC4PC boards in the $100 range and they look very nice but I was hoping to find something much cheaper to get me back on my feet. I see all of the $30 boards on ebay but nothing has a DB25 output that will plug directly into the Xylotex.
    I would GREATLY APPRECIATE if a someone could help a brother out.
    Thank you and God Bless!!!!
    Chris
    Just plug the Xylotex into the parallel port, and spend $5 at Mouser or Digikey for the Molex connector that plugs into the Xylotex an gives you access to the extra pins.
    You don't really need a breakout board.
    I have a SuperPID, hall effect home switches, and auto zero plates wired directly to my Xylotex. The only thing I had to do was add a pull up resistor for the auto zero plates.
    For jogging, try an XBox 360 controller or a Shuttle Pro. Neither need the parallel port.
    Actually, you don't need the connector. My Xylotex is 7 years old, and doesn't have screw terminals. You can connect your probe and E-Stop right to the Xylotex screw terminals.
    There's a picture here showing how to wire switches to the Xylotex with a pull up resistor.
    Limit Switches~Solsylva CNC Plans
  1. break out board
    By dfurlano in forum Gecko Drives
    Last Post: 11-22-2011, 06:41 PM
  2. Break Out Board.
    By Ark1 in forum CNC Machine Related Electronics
    Last Post: 09-09-2010, 12:20 AM
  3. C10 break out board
    By jhowelb in forum Uncategorised MetalWorking Machines
    Last Post: 10-29-2009, 12:36 AM
  4. When do you add a break-out-board
    By dan dimock in forum DIY CNC Router Table Machines
    Last Post: 02-15-2007, 03:11 AM
