Hi guys I just bought a 4x4 plasmacam table,,I need some suggestions on cutting speed and heat for 3/16 and 1/4 thick mild steel ,,and same for aluminum,,,thank u
You should follow the plasma torch manufacturers recommendations. In the manual they should have at least a subset of combinations for thickness, amps, type of consumables ad speeds to get you started. From what I've seen here, the Hypertherm recommended parameters in the manual are spot on.
Matt
