585,761 active members*
4,246 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Escape wheel for wooden gear clock
Results 1 to 6 of 6
    Mar 2012
    I would like to design an escape wheel for a wooden gear clock with Bobcad. Any help would be greatly appreciated.
    Dec 2008
    4548
    I dont really know what that is, but I googled it and saw a couple different shapes.. This video should get you going. It will show you how to make a radial array of a specific shape at a given value..
    Clock Sprocket - YouTube
    I also used the sprocket command and then changed the point shape a couple different ways I saw in pictures...
    Feb 2012
    How do Pinhead.
    Design your escapement wheel around a proper clock pendulum pallet escapment and use that as the escapment.
    I've heard that wooden ones don't work so well as humidity temperatures make the clock stop.
    As for the wheel itself....take a photograph of one without the shaft if possible? then import it into a program that can convert the photo to a vector,save then import into bobcad.
    You should be able to then alter the size to suit.
    Mar 2012
    Hey thanks for the input!!!:cheers:
    Feb 2008
    217
    Or try this, I believe it will output HPGL
    Gear template generator
    We're not in business to make parts, we're in business to make money, making parts is just how we do that.
    Dec 2008
    4548
    Quote Originally Posted by Joe S. View Post
    BobCad has a gear generator. It just didnt do escape shapes.
  1. Wooden Clock Gears
    By wallyign in forum WoodWorking Topics
    Last Post: 04-18-2012, 04:43 PM
  2. Adjusting time on a Wooden Clock
    By Mogal in forum WoodWorking Topics
    Last Post: 01-02-2012, 10:36 PM
  3. Gear Clock
    By abbtech in forum Wooden Clocks
    Last Post: 03-19-2010, 10:51 PM
  4. using cnc to make a wooden clock?
    By panofish in forum Benchtop Machines
    Last Post: 07-10-2008, 07:27 PM
