Originally Posted by
freecncplans
If you want to focus more on building and not so much wiring, I suggest going with the pre wired box. I use a Bosch 1617EVS and cut 3/4" birch ply, pine and oak with it. It is a good setup.
I use the 640 oz for the z axis and 5 start screw.
I run this setup at 2,000 IPM rapids and 150+ IPM cutting reliably. I ran the 23 setup and Gecko 540 for a couple of years. It wouldn't cut 3/4" in a single pass. The Nema 34 does without a problem.
The BOB is 4 axis with a slave for the x. It also has 2 15 amp relays for the router and dust collector. I am going to building another machine and I already plan to be buying another setup from CNCRouterParts.
Sean
