Hi All,
I've started to do some test cuts on my new machine. First just some simple straight cuts on mdf that seemed to go pretty well.
Today I tried some more complex shapes cut out of plywood that didn't go so well.
I was cutting 18mm pine plywood using a 1/4" 2 flute downcut carbide endmill. Cutting speed was 3600mm/min (140 inch/min) at 18000rpm cutting 4mm passes. It started out cutting well (photo attached) nice and clean and each pass was in the exact same line as the previous one. After about 10 minutes of cutting I noticed each pass started to step over slightly on the last. This got worse and worse (photo attached) until I decided to stop the g code so I didn't break the cutter.
The culprit is the Y axis that isn't returning to the right spot each time. The Y axis is running CRP R&P, Gecko Nema 23 motors and Gecko G540 Drive.
Any help would be very appreciated!
Cheers,
Rory
