I need a little advice here. I'm finishing a pocket with a Melin 1/2" 4 flute HSS end mill. Feedrate is 22.79IPM. Spindle speed is 1203 RPM. The pocket was roughed with a carbide insert mill, and 0.030" was left on the walls and on the floor of the pocket. The metal is A36 steel.
The problem is, I'm getting a nasty pattern of circles on the floor of the pocket. For the right hand pocket, I tried cutting the feedrate in half and upping the coolant flow, but it's still making these marks. I'm not hearing any unusual sounds from the cutter.
What's causing these, and how do I get rid of them?
Frederic
