I can’t find an easy to understand method to size stepper motors and below is what my interpretation is of the various pages a read.
My new hobby CNC router will be made out of 1/2" thick aluminum plate and it will use 3/4" SBR supported rails, SBR pillow blocks and 0.63” ballscrews from overseas. The approx. dimensions of the machine are Y=36”, X=24”, Z=10” and the estimated weights of each axis is Y=100 Lbs, X=35 Lbs, Z=20 Lbs (incl.spindle and motor). Assuming a 500 IPM and the heaviest weight to be 100 Lbs, I calculated the following:
(500*100) / 531 = 94 Watts
Estimated drive Amps = 3A, 40V, or 4A, 30V
Do the above sound ok?
