585,992 active members*
5,428 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Mar 2012
    103
    Simple solution....but can't afford to just keep trying one until I find one that works. I was hoping more for a referral for a known working solution.
  2. #22
    Jul 2009
    419
    Don't know about barcodes but couldn't the same thing be done with a qr code and a webcam?
    Sven
    http://www.puresven.com/?q=building-cnc-router
  3. #23
    Mar 2004
    1661
    Quote Originally Posted by beltramidave View Post
    Read the setup guide and make sure it's configured with correct language etc. If you open an editor or terminal and scan a barcode the input from the barcode should appear as normal keyboard text in the editor. If not, it's not configured to be a wedge (a scanner can act as a wedge scanner even though it's connected to its own USB port) or you might have a weird config OR your scanner need a driver to be able to act as a wedge scanner. It must act as a wedge otherwise the whole idea will not work.
    You can also try to find anything useful here: https://help.ubuntu.com/community/BarcodeReaders
    i did see your question at Linuxforums, but I'll continue in this thread.
    @CaptainVee, that's not possible to do without having an app that interacts as a keyboard interlayer.
  4. #24
    Mar 2012
    103
    Bar code update
    I believe that I have figured it out. I was able to set up the Honeywell scanner with a "Intercharacter Delay" which places a short (ms) delay between the transmission of each character of scanned data.
    I am now able to use "o+filename" (ex: otest) to create my barcode and only scan once to open, populate and load the program. This will save a lot of time.
    Thanks for the help!
  5. #25
    Mar 2012
    103
    This is a known working solution.
  6. #26
    Nov 2013
    er.. sorry for my late reply, i hope i also can do some favor .i know a website about barcode scanner , or barcode reader, found on google, it offer the guide to use barcode scanner, yo may check it .
  7. #27
    Our barcode scanner and readers to capture the data that matters most at the retail POS, patient bedside, and manufacturing production line.
Page 2 of 2 12
  1. Enroute Barcodes and Labels
    By Dave_Fusion in forum EnRoute
    Last Post: 03-05-2012, 05:57 PM
