585,760 active members*
3,844 visitors online*
Results 1 to 7 of 7
    Oct 2005
    40
    Exclamation MASTERCAM 9.1 TOOLPATH GENERATION for Mach3
    I am new at CNC, and just converted my Smithy 1200 LTD to Mach3. I use MasterCam 9.1 to generate my G-code. Learning it was painful, so to help others I put together an article describing the process. I tried to be as brief as possible (challenge for MC9), and added as many screen shots as reasonable. I compiled it with emphasis on smaller machines running Mach3 and similar controllers. Find it on my server at:
    http://www.novalab.org/mc/mastercam_tutorial.pdf
    Before you criticize me too much, remember I am an electrical engineer and not a machinist . I hope you find it useful, and am looking forward to any feedback.
    Regards,
    Chris :banana:
    May 2005
    21
    Hi Chris...the link aint going nowhere please fix it...
    As for me ,am a licensed MC user ( Lathe only) seriously....Mill just playing with it.
    I can see a good reason to make a good post for the Mach3 controller.
    I dont have any Hobby Cnc here at home ( not enough time) but am curious about them.
    Oct 2005
    40
    Works for me. "Try save as"... I tried attaching it, but it is too large for this forum.
    Chris
    Save as works, but it won't let you open it in IE?
    Oct 2005
    40
    I just looked why you can't open the link in IE. Here is an excerpt from the server error log:
    [Tue Nov 22 21:35:49 2005] shpd: access to .../novalab.org/.../mc/mastercam_tutorial.pdf failed for 71.131.45.29, reason: external link to non-page refused from http://www.cnczone.com/forums/showthread.php?t=15081
    So, you will have to "Save As", as the forum will nit let you link to PDF file directly.
    Has anyone been able to get this file?
    Chris :banana:
    Nov 2004
    321
    Yes.
    Open in Mozila Firefox with PDF Download and Save As.
    Dec 2005
    390
    The tutorial (and a lot of other good stuff) can now be found at:
    http://cnc.novalab.org/mach_files.htm
