585,700 active members*
3,439 visitors online*
    Mar 2012
    Mazak Nexus 510C-II Coolant Mist in the fans
    Is anybody out there that has a Mazak Nexus 510C-II that gets coolant mist sludge in the spindle cooling fan on top of the machine or even get into the cooling fans for the different drives? If so what have you done to prevent this from happing?
    Jun 2008
    150
    We use individual mist collectors, smog hoggs, Torit, on our MC's. Coolant still gets in fans. We change/clean CNC filters every 2 weeks and they are black and slimey. Oilcooler filters- same interval, though they could go a little longer.
    Some integral spindle motors have some type of fan/ filter deal to cool them and the air/mist is piped straight in to the stator/rotor area, et al the old integrex Mark II series. We found it the hard way- while we were pulling the spindle. Neglected to change or service this filter because of ignorance and the filter blinded, collapsed and then sucked oil, coolant mist and filter debris right up into the motor internals. This in turn caused two labyrinth slingers to friction weld together-locking up the spindle.
    Good luck with this fight!
    Lee
  1. Measuring Probe Nexus 510C
    By Nine Blue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-06-2015, 12:13 PM
  2. nexus 510c alarms
    By CLATHAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-27-2011, 02:53 PM
  3. Mazak Nexus 510C II Probing
    By KTPDAN in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-28-2011, 07:29 PM
  4. LOOKING FOR NEW HIGH QUALITY VMC IN NEXUS 510C CLASS
    By rmhydro in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2010, 03:20 AM
  5. Nexus 510c manuals
    By inioxos in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2010, 10:23 PM
