584,829 active members*
4,982 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Using Haas 300 bar feeder w/ Haas TL1 tool room lathe
    Mar 2012
    We have a Haas 300 servo bar feeder. We also have a Haas TL1 Tool Room Lathe w/ an hydraulic collet closer (for B10 collets).
    We are trying to use the 300 bar feeder with the TL1, but there are compatibility issues and the TL1 can't communicate with the bar feeder.
    Does anybody know how to make these 2 machines compatible?
    Dec 2008
    717
    Usually a control has a "bar feeder interface"
    My guess is you need that.
    Tim
    Aug 2010
    579
    Haas Factory Support
    This interface is not plausible. You would need to do the interface and the adapter. There are no provisions for setting the height to the TL either. You are better off getting a 3rd party barfeeder that can easily be interfaced and M-code activated.
    Ken Foulks
  1. Haas bar feeder problem
    By cnc1968 in forum Haas Lathes
    Last Post: 03-21-2012, 12:32 AM
  2. Haas ST20 Lathe Tool Offsets
    By Wod in forum Haas Mills
    Last Post: 02-07-2012, 06:12 AM
  3. HAAS HL-2 Lathe tool setter
    By claudem56 in forum Haas Lathes
    Last Post: 11-17-2011, 03:39 PM
  4. Inconsistent Haas 300 bar feeder
    By Dweezle69 in forum Haas Lathes
    Last Post: 07-14-2011, 06:42 PM
  5. Bar Feeder Program for Haas SL-20
    By wganders in forum Haas Lathes
    Last Post: 05-03-2009, 04:01 PM
