585,764 active members*
4,571 visitors online*
    Mar 2012
    Mach3 showing wrong side of work piece?
    HI, Guys I,m new to Mach3. I,m using an older micro proto running Mach3.
    When I,m drilling a bolt pattern the machine is drilling the hole on the left side
    of a plate Mach thinks it,s on the right side.
    Axis scaling?
    Check your axis scaling in Mach3. It should be "1" and not "-1". Hope it helps
    farmertom
    farmertom
    http://cncartwork.weebly.com/index.html
    Or, you have your machine set up with one axis backwards.
  1. Work piece size?
    By cgroves in forum SprutCAM
    Last Post: 02-13-2011, 10:22 PM
  2. Mach3 make reset after showing the 1st splash picture...???
    By ata in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2007, 04:33 AM
  3. Cutting a work piece.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 03-20-2007, 07:02 AM
  4. Wrong side of circle is connected.
    By rocky in forum GibbsCAM
    Last Post: 08-24-2006, 03:31 AM
  5. RFQ: Lathe work, one piece.
    By SCCoupe in forum Employment Opportunity
    Last Post: 07-24-2006, 11:58 AM
