585,591 active members*
2,629 visitors online*
Page 2 of 3 123
Results 21 to 40 of 57
  1. #21
    Oct 2005
    186
    I think Dan is using the 7310 Porter Cable on HobbyToolPlans.com. Thats probably the one I'll pickup.
  2. #22
    Oct 2005
    186
    Btw, I am getting about 30 IPM on my machine. How does that sound?
  3. #23
    Jun 2005
    476
    Quote Originally Posted by WarrenW
    First, I just found this thread today and I'm impressed with how fast you're getting everything together!
    30 IPM is pretty impressive for those little xylotex motors!! I'm using the same stepper motor/ driver kit that you have to drive a test fixture. When I read your first post in this thread, I started to worry they wouldn't be powerful enough. And then I caught up to your latest post -- 30 IPM!
    I have the 0690 router, but haven't installed it on a machine yet. Unless you're going to run 600IPM, the routers you're looking at will hardly strain to cut 1/8" birch!
  4. #24
    30ipm is pretty slow, and iseally you'll want a slower spindle speed to prevent or minimize burning. Slower speeds are much quieter, too. Here's a pretty good deal for a variable speed router with good power. http://www.amazon.com/gp/product/B00...lance&n=228013
  5. #25
    Jul 2005
    668
    Quote Originally Posted by joe2000che
    This is a funny coincidence!
    I went to Lowe's today to get material to hook up my new HF dust collector and stopped by the Sears repair/recondition outlet and snagged a similar router for $29.88. 2 hp and VS with dust port. Knew it was good...just didn't know how good.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
  6. #26
    Feb 2005
    578
    Anyone ever tried one of those Hitachi routers? Price seems to good to be true. But they are a reputable company.
    I just got one of these Bosch recons. 2 1/4hp, quiet, variable speed, magnesium case, 1/2" collet. I really like it.
    http://cgi.ebay.com/Bosch-Variable-S...QQcmdZViewItem
    Steve
  7. #27
    430
    You can do far better than 30 ipm with the xylotex and those steppers. I rapid at 80 (over 100 on the diagonal) with 24V supply and 3/8-12 acme leadscrews with the xylotex board and 128 oz in steppers. What software are you using, mach 2 and 3 is what I am using.
    colin
  8. #28
    Oct 2005
    186
    I'm using Mach 3. 30 IPM seems okay for me but I'll know when I actually start cutting this week. I have my xylotex set to 3.5V for each axis so I can't increase that anymore. It may be a setting in the software to tune it for faster movement. Anything that is faster and more precise than using a scroll saw is good to me!
    As far as routers, I didn't know you could mount a larger router like these mentioned above on the setup. I'll probably stick with the porter cable 7310 just for cutting 1'8 inch birch. The great thing about Home Depot is you can always return!
  9. #29
    Oct 2005
    186
    What type of bit is used for cutting in wood like cutting through 1/8" birch sheets?
    Thanks!
  10. #30
    Oct 2005
    186
    I just got back. The only router I really liked was one of the Porter Cables but it was alot of money. I decided against the trimmers and your right on the variable speed. I don't want to burn the wood. I found a Hitachi 2-1/4 HP router at Lowes for $115 and its variable speed. So I got that one.
    I wasn't sure what bit to get so I got a straight cut 3/16" bit at Sears. I'll let ya know how it goes.
    Warren
  11. #31
    Aug 2004
    3215
    Warren
    Do you have the model number i want to check it out Hitachi is a descent brand. Going to buy a router today.
    Joe
  12. #32
    Oct 2005
    186
    You can go to Lowes.com and enter: hitachi router
    And this is one of them:
    Hitachi
    Variable Speed Fixed Base Router
    Item #: 118359 Model: M12VC
    $114.00
    I liked that once I took the base off, it looked like it would be easy to mount also.
    More specs from the site:
    Powerful 11 Amp, 2-1/4 HP motor to cut through tough hardwoods
    2-stage motor release clamp for accurate depth adjustments and base changes
    Electronic speed control maintains constant RPMs even as load varies
    Nickel plated motor housing for smooth depth adjustments
    • See Our Rebates
    Horsepower: 2-1/4
    Amps: 11
    No-Load Speed (RPM): 8,000 - 24,000
    Depth Capability: 2.6"
    Type: Fixed
    Max Collet Capacity: 1/2" and 1/4"
    Weight: 7.3 lbs.
  13. #33
    Oct 2005
    186
    Also, it was in a regular brown box so it doesn't jump out when you look below for one in the box. I almost missed it thinking they were out of them.
  14. #34
    Aug 2004
    3215
    I called and the lowes by my house has 6 in stock, so guess where i'm going after work, I like it because of the 11amps and down to 8,000 rpm.
  15. #35
    Quote Originally Posted by spalm
    I know someone with an older Hitachi 3HP plunge router, and he says it's a great router.
  16. #36
    Warren, Make sure you use carbide bits, HSS won't last long at all. I buy a lot of bits from Eagle America.
    http://www.eagleamerica.com/product.asp_Q_pn_E_102-0102
    Spiral bits will cut faster and quieter.
    http://www.eagleamerica.com/product.asp_Q_pn_E_106-0202
  17. #37
    Oct 2005
    186
    Hey Joe, did you pickup that router? Or choose another? I just made the mount for the router. Like many of them, I like the smooth round case of the router once the base is removed - makes it easy for mouting. I went to bolt mine on today but the bolts I have are 1/2" too short so it will have to wait till tomorrow since no one is open on Christmas. Thats alright anyways... I'm so tired from opening and putting together all my kid's presents Santa brought them!
    Warren
  18. #38
    Aug 2004
    3215
    Warren
    Yes I got it, Looks like it will work very well, thanks again, At 8,000 prm it is super quiet, and full speed 24,000rpm it is slightly queter than my rotozip.
    Do you have pictures of you mounts?
    http://www.cnczone.com/forums/showth...300#post124300
  19. #39
    Oct 2005
    186
    I got my router mounted and made my first cut today! I ran the circular pocket wizard in Mach 3 that cut both these holds shown below.
    I have to find a better way to hold down the wood so the gantry does not hit anything. I don't want to put a bottom sheet under because all of my work will be cutting through 1/8" birch and other wood.
  20. #40
    Mar 2004
    636
    Congradulations
    Warren,
    Congradulations on getting it working. It appears as though you did an excellent job!!!
    Dan
    www.hobbytoolplans.com
    Check out what I am working on at www.routerbitz.com!
Page 2 of 3 123
