I have a Hartford VMC850 with a Meldas M520A controller, I was hoping it was similar because I'd like to tweak my toolchange program, but my edlk_c param is already 0 and I cannot access any macro programs. I'll dig out the manual and see if I can help you in any way.
Edit: Found a helpful website "If you inadvertently lose the FIXED CYCLES, they are still stored on EEPROM so all you need to do is change FIX_P to 1, go to INPUT screen and enter #(4) and press INPUT. The FIXED CYCLES will be loaded from EEPROM."
Not sure if that will help?
MITSUBISHI
This might be similar to the program you are seeking
http://www.cnczone.com/forums/fanuc/...acting_up.html or something like
YANG
Good luck and let us know if any of this was helpful. Program 9001 on that last link looked promising
