Try and stop it at different tools and see if any work.
I have checked with Encoder and Sensor and they are working fine.
How did you check the encoder?
Some turrets have slowdown switches, is the turret servo driven or hydraulic driven?
If servo you need to look at feedback and parameters.
If hydraulic you need to look at switches. There are many switches.. say you have 8 switches. 1 clamp/unclamp, 0,1,2,3,4,5,6,7 are all going to be inputs. The combination of them switches determines position. 1 switch will be a slow down switch.
Do you get any alarms?
Jack of all, master of none
Galveston, TX
