Hallo..
can somebody help me how to switch on the SSS function and HPCC function on M720.
Thx before
Hallo..
Thx before
SSS (super smooth surface) is generally an option on the 720's, but if
you have this option, you simply need to set parameter #8090 to 1
I'm not sure to what HPCC refers to, but if it has anything to do with
High Speed Hig accuracy, these are also options
HSHA can be G05 P10000 (or G05 P2) depending on params
yupzz..oke thx..i had done and for M720 there are have 2 way
1. G5 P1/P2 it was for SSS
2. G43
G100 Q4(can chosse Q1 until Q9)
G5.1 Q1
explaination for
-Q1 until Q3 is for Velocity (rough)
- Q4 until Q6 is for precison it sam with G5 P10000 or P2
- Q7 until Q9 for smooth
With G5.1 Q1 - the "1" with the Q is not an argument
that can be set (i.e. there is no G5.1 Q2).
In your example there is a G100 in line 3. This is not
a Mitsubishi G code, it might be something developed by your
Machine Builder, or a user G-Code Macro.
I would recommend ensuring parameter 1267.1 = 1
and using G05P10000
When 1267.1 = 0 you can use G05 P1, and G05 P2
When 1267.1 = 1 you can use G5.1 Q1 and G05P10000
G05P10000 is the way to go. It will give you the fastest possible
thru put.
There are a number of user parameters that control a variety
of HS/HA functions.
You can see these parameters under SETUP kardkey -> USER softkey
then Hi-Prec Params
