585,705 active members*
3,737 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > control stepper motor driver controller L297 using Pic ????
Results 1 to 6 of 6
    Oct 2005
    104
    Dears,
    please help me to control stepper motor driver controller L297 using Pic micro controller .
    i need to generate the step and direction and enable .
    how to do that ?
    watzmann
    24220
    Lots of Apps on the PicMicro site?
    http://ww1.microchip.com/downloads/e...tes/00822a.pdf
    Al.
    Albert E.
    Oct 2005
    104
    the funny thing had happned ,
    i did connected Enable o 5 volt , and set the direction . now when i only touch the step wire with my finger the stepper motor rotets ...... why ?
    watzmann
    Oct 2005
    104
    thanks for your link , unfortuantly i'm not so good in assembly so i'm trying to find in C or PIC basic .
    what if i wrote a code to generte puleses on thes step pin every 50 micro second , will it work ?
    watzmann
    Jun 2004
    8
    Hello watzmann,
    Quote Originally Posted by watzmann View Post
    ... when i only touch the step wire with my finger the stepper motor rotets ...... why ?
    Your body acts a a receiver for any stray AF (50 or 60 Hz power line frequency) and/or RF in the vicinity. Your finger conducts that hodge-podge of frequencies into the CLOCK input of your L297. Whenenver the chip detects a rising edge, it will take that as a clock signal. Not very reliable and potentially dangerous...
    All the best,
    Fred
    1695
    Is there a reason why you want to use the L297? It's a very old design. Better chips are available. The tb6560 requires no microcontroller. But you will need to make sure to follow the proper power sequencing.
  1. Mini-tech 2 and Stepper Motor Driver Controller?
    By art4x4 in forum Stepper Motors / Drives
    Last Post: 05-20-2011, 05:38 PM
  2. Cheap stepper motor controller and driver
    By webbyguy in forum Stepper Motors / Drives
    Last Post: 08-18-2010, 07:20 AM
  3. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
