585,908 active members*
3,681 visitors online*
Results 1 to 8 of 8
    Nov 2007
    79
    A axis error 18M
    hello
    i have a problem with dividing head (A AXIS) machine is vmc FANUC 18M
    when i switch on the machine all axis goes fine to home position XYZ&A
    No (APC) provided with the machine. the problem is after switch off the machine and next day i zero return the axis as usual the A axis gives me error about 10 degrees comparing with the previous homing position,
    so if some one could tell me where is the problem and how to fix it
    for example, do i need to set zero reference for A Axis ? if yes what is the procedure??
    any help will be appreciated
    thnx
    Oct 2009
    297
    Quote Originally Posted by nabil_elbadri View Post
    hello
    thnx
    Do you have the original parameters for the machine?
    What do you see in parameter 1815?
    Regards
    Alex
    Mar 2012
    19
    what A-axis use for?for tools magazine?if that right,i think your a-axis used PMM (power mate manager). U can acces PMM with press SYSTEM, then press RIGHT softkey untill PMM menu appear.if u want zeroing the axis,set the parameter 11 in PMM bit 0 and 1.
    Jul 2009
    80
    What kind or Brand of Rotary table do you have assembled?
    Model?,
    Regards
    Robby
    Nov 2007
    79
    hi guys
    thnx for ur reply
    it's a dividing head with small chuck diameter about 200 mm capacity,can be fixed on the table in horizontal or vertical positions only
    the manufacturer is LCM the motor drive is fanuc
    what i need is how to correct the 10 degrees error?
    i saw the parameter 1815 it;s value all zero
    about the parameter i don't have a back up and i don't think i need the back up because it's only a matter of how to reset zero again for the A axis .
    thnx again for any help
    Oct 2009
    297
    hi guys
    thnx for ur reply
    About the backup, I was thinking that if the machine was working fine then you should check the original parameters to see if a parameter got mixed up.
    Do you see the A axis in the screen? if you do zero return without powering off the CNC, Does the position change everytime you do the zero return?
    Regards
    Alex
    Feb 2009
    6028
    So, the axis varies 10 degrees, or did it suddenly shift 10 degrees and stay there on zero return?
    Grid shift is parameter 1850, that controls distance from marker pulse to actual zero. If it varies back and forth every day or whatever, I've seen where the zero return switch is too close to the marker pulse on the encoder, sometimes getting the pulse right at the switch, sometimes getting the next marker pulse. A small adjustment of the switch usually cures that.
    Nov 2007
    79
    hi guys
    thnx for ur reply
    the situation is when ever i switch on the machine and zero return the A axis, i get 10 degrees different comparing with the marker on the scale and even if i rotate the axis in manual (handle) mood and call back zero return again it goes to same position(machine still switched on)
    plus in relative value when i set zero to relative and turn the axis manually and then call back zero return it goes back to same position and the relative value doesn't give me my zero reading where i set it to zero
    i believe that i need to set zero reference point for the axis again (only for A axis)
    about ur qustion alexfanuc , yes i see the A axis on the screen and the reading is changing as the axis rotating in general the machine works fine exept the problem of the A axis .
    for example i send a program from pc to machine (4 axis program) i have to finish the machining complete with out interference in the program like optional stop or switch off the machine and finish the program next day .
    if i do so i lose the angle position where i stop last time
    thnx again for any help or suggestions
  1. Z AXIS ERROR
    By efmautoclutch in forum Milltronics
    Last Post: 04-03-2011, 05:12 PM
  2. Z Axis error
    By ChattaMan in forum Fanuc
    Last Post: 01-05-2010, 09:16 PM
  3. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  4. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
  5. X axis error on a 325
    By BugEyedValiant in forum Tree
    Last Post: 07-06-2009, 12:21 AM
