585,967 active members*
4,302 visitors online*
Results 1 to 6 of 6
    Nov 2011
    Deep draw press
    Are most kitchen sinks manufactured by a deep draw press? I Think the av. gauge of the stainless steel sink is 18 gauge avg. sink so what tonnage do you think the press would need to be. Also the deep draw presses I have seen do not look like they would be to hard to build.
    Jan 2007
    175
    Looks like a hydraulic press for sure 1000ton
    http://youtu.be/DgAEpm3Jxag
    Rockcliff Machine Inc.
    http://www.rockcliffmachine.com
    Jul 2005
    12177
    Quote Originally Posted by mblount View Post
    ..... Also the deep draw presses I have seen do not look like they would be to hard to build.
    I think a 10 ton press would be fairly simple to build.
    A 100 ton press is probably within possibility because I have a very well equipped home shop (and a 10,000square feet manufacturing facility )
    A 1000 ton press would be a real challenge.
    Nov 2011
    Quote Originally Posted by Geof View Post
    Is there a forum that talks more about presses?
    Feb 2009
    6028
    Looks like that could very well be a Hydroform press.
    [ame=http://www.youtube.com/watch?v=gpYsExL_hUQ]Sheet Hydroform Production - YouTube[/ame]
    Hydroforming - Wikipedia, the free encyclopedia
    Not so easy to build that sucker.
    Jan 2007
    175
    Not sure if I have ever come across an actual press forum, you might have some luck with possibly looking for a mechanical engineering type forum, they would be the kind of guy's that would be doing this type of calculation for loads and tonnage
    it would be amazing to see a DIY press on this scale !!!!
    Good luck with your project,
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. How Do I draw this?
    By SPEEDRE in forum Solidworks
    Last Post: 05-21-2011, 11:30 PM
  3. RFQ small Deep draw dies.
    By jimmy111 in forum RFQ (Request for Quote)
    Last Post: 03-26-2011, 10:38 PM
  4. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
