585,888 active members*
4,083 visitors online*
    Apr 2004
    61
    Question Interface module on 11M
    Hello.
    I have a machine with a fanuc 11M, I am getting the alarm as if all the hard limit were pressed. I checked the diagnostics and all are zeros without change when pressed. on the module the signals are present as the leds act when I press the LS.
    also I checked the Fibre optic cable and looks ok. is it possible that the module is not sending the signal to the main board?
    there is any way to check the modele? what else can be causing that problem?
    Jorge B.
    jorbercnc.com
    Apr 2004
    61
    Unhappy Any one to help
    please someone give me your opinion, thanks
    Jorge B.
    jorbercnc.com
  1. if you need ic and module,please tell me.
    By keithshen in forum Want To Buy...Need help!
    Last Post: 01-07-2008, 02:07 PM
  2. Is anyone using the Lathe Module?
    By clevang in forum BobCad-Cam
    Last Post: 12-11-2007, 07:07 PM
  3. Lathe Module
    By rodneydeeeee in forum BobCad-Cam
    Last Post: 08-28-2007, 12:09 AM
  4. Please need help on I/O Module
    By yeager in forum CNC Machine Related Electronics
    Last Post: 01-13-2006, 03:19 PM
  5. Another learning module
    By Chunky in forum G-Code Programing
    Last Post: 06-11-2005, 11:04 AM
