585,715 active members*
4,648 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Drilling my CRS rails for mounting - what size hole?
    Jan 2012
    22
    It seems like such a simple question, but it really isn't.
    I picked up the cold-rolled steel rails for my machine build this week, and this weekend I'm planning on getting the holes drilled for mounting to my 8020 table. I'm using 4" wide CRS mounted to 3030 struts for the X-axis, so I'm thinking two bolts (one in each T-slot) every 12". The screws are 5/16 - 18, and I'm just wondering how much clearance I should give the mounting holes to account for both the tolerance of getting all 12 holes lined up perfectly and also allowing for a little extra play to have when aligning the two rails once I get the gantry installed.
    According the the tap chart I have, a "free fit" for that size bolt is to use a Q drill, which is only about 20 thousandths over the bolt diameter. I'm thinking that I should drill them out a little more - like maybe going a 11/32" drill.
    What have other people done on their rails?
    Aug 2006
    143
    I used 3/8" for two reasons. One, I have a 3/8" indexable spade bit and two I felt that having a little room on the bolts would allow me to align the CRS to the 8020. I drilled the holes with a CNC mill so mostly it was reason #1
    Derek
    Jun 2011
    Using a bridgeport mill I drilled my mounting holes 11/32.. I drilled holes like every 3 inches..
    Also in a bridgeport I drilled and reamed 8mm holes in 4 locations and used roll pins to positive locate the rail to the extrusion frame...
    Heres a picture of my rails
    Jan 2011
    242
    CNCRouterParts
    3/8" is what CRP suggests.
    Jan 2012
    22
    Quote Originally Posted by RossMosh View Post
    CNCRouterParts
    Oh, I hadn't noticed that one. Thanks!
  1. Replies: 4
    Last Post: 03-24-2010, 04:40 PM
  2. C6 stand mounting hole pattern specification
    By tomchen911 in forum Syil Products
    Last Post: 01-06-2010, 07:52 AM
  3. mounting location for rails
    By kevintshaver in forum Linear and Rotary Motion
    Last Post: 03-02-2009, 05:52 AM
  4. X3 Base Mounting Hole Distances?
    By caleb105 in forum Benchtop Machines
    Last Post: 02-22-2009, 11:04 PM
  5. Taig mill bottom base mounting bolt hole spacing pattern
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 01-20-2009, 09:42 PM
