585,956 active members*
4,286 visitors online*
Results 1 to 7 of 7
    Apr 2012
    Akira Seiki Manual needed
    Help!
    I've aquired a 1999 Akira Seiki Performa V-4C VMC with a Mitsubishi M64 CNC. we are now in the process of getting it up and running. The unit did not come with a manual for the Akira Seiki or the Mitsubishi controller. I called the Akira Seiki USA company, but no luck. Does anyone know how I can obtain manuals?
    Any and all help would be appreciated.
    Apr 2012
    I have almost the exact same problem. I just got a 1998 Akira Seiki Performa V-4A with Mitsubishi controls. I just rebuilt the linear guilds and replaced the Y-axis ball screw. I got got someone to make me a photo copy of a similar, but newer model, but it isn't quite the same and is only so helpful.
    I would also greatly appreciate help in finding the proper manual.
    Jan 2011
    Manuals for the operation and programming of the Mitsubishi
    control can be downloaded for free from Mitsubishi Electric
    Mitsubishi Electric Automation Inc. - MEAU Home
    Some of the panel operations common to most machines
    is covered under what mitsubishi identified as the
    "Operations" or "Instruction" manual.
    You would need to figure out which Mits control you have,
    but in about 1999 it may be a Meldas 60 series control.
    Once you know your control type, then follow the instructions
    on the meau download link, and choose CNC controls -> 60 series
    for example.
    Sep 2017
    21
    Hi were you able to get manual of PERFORMA V4-A
    I have a similar used machine which I bought recently V-2A with m64 Mitsubishi control 2000 model.
    Facing some issues with it want to do a ATC recovery.
    Can you guide on it .
    Quote Originally Posted by the75animal View Post
    Re: Akira Seiki Manual needed
    Hello, I am looking for manual on Aikra Seki HV3100. We bought in 2008, but can't find the manual.
    Mar 2024
    4
    Hello. Did you manage to get the documentation?
    Apr 2024
    Quote Originally Posted by Vasilii View Post
    Head Soccer
    Apparent. If not, can you have any other method?
  1. AKIRA SEIKI RMV 250 or AKIRA SEIKI RMV 160
    By lexa345 in forum Machinery Manuals / Brochures
    Last Post: 09-23-2013, 10:00 PM
  2. Hitachi Seiki mini center manual needed
    By surfit in forum Machinery Manuals / Brochures
    Last Post: 11-06-2012, 08:32 PM
  3. Akira Seiki manual neded
    By the_juncky in forum Machinery Manuals / Brochures
    Last Post: 06-03-2012, 07:32 AM
  4. Akira seiki
    By HTMTRADER in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2010, 11:04 AM
  5. Akira Seiki, or which VMC should I buy???
    By building it all in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2009, 01:33 PM
