Hey guys,
I have a preowned CINCINNATI series 2 Arrow 500 (Model NO: EKK) and it can not be aligned now.
Error message as follows:
Alarm 39-148: NCA-Axis Pulse Enable Alarm
Cause: An alarm is being reported by the X axis drive in APC rack 5
(Siemens 611 drive node address 7)
There is no feedback being received from the drive
[X-AXIS5MDW BIT 13] (MW-PULSE_ENB) is OFF.
Remedy: Check the X axis drive fault indicator L.E.D.
Reset fault on drive. Refer to Siemens documentation for diagnostics.
Reset but still could not solve the problem.
I am not sure if the Mechanical Configuration is right or not since the machine parameters are not the same as default.
Scale feedback is used for both X and Y axis (Primary Feedback: Scale; Motor Connection: Direct; Index Invert A & B, Distance Coded are selected)
Encoder feedback is used for Z axis (Primary Feedback: Motor Direct; Motor Connection: Direct; No writing is selected)
Any expert on this?
I really want to hear some thoughts
Many thanks!
