585,997 active members*
4,990 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Anybody doing job shop work on C6?
    Nov 2005
    34
    Anyone out there doing (or want to do) any job shop work on their C6 lathe (or any other CNC lathe)? I have 3 parts I need made on a continual basis (drawings attached). All are aluminum, involve threading, and are about 2" diameter. I order in batches of 50 to 100 about 8-10 times a year (hopefully that will increase). Been doing this for over almost 2 years so I'm an established customer. My current supplier went out of business suddenly (IRS problems).
    Drawings are attached. The 3 tapped holes on the "Bottom Cap" can be omitted as that operation is generally beyond the capabilities of most "home lathes" and we can do it as a second op in house. Likewise with the small threaded hole in the "Top Cap". Drill the tap hole but no need for "hard tapping" capabilities on your lathe. We can do the tapping as a second op.
    Going to put this out for general bid, but I thought I would give members of the group a chance. This is a nice job to run in the evenings and weekends. Other work could come from this for someone that does a good job.
    I have references to show I'm a legit customer for anyone that wants them.
    Gary
    895ISP, LLC
    Attached Files Attached Files
    Apr 2007
    157
    Sent you a PM
  1. SHOP; looking for work!
    By denmar in forum Employment Opportunity
    Last Post: 02-01-2011, 03:19 PM
  2. new shop looking for farmed out work
    By arrowhead,AR in forum Employment Opportunity
    Last Post: 05-08-2010, 04:45 PM
  3. Tool shop needs work.
    By timoty in forum Employment Opportunity
    Last Post: 04-28-2009, 03:33 PM
  4. machine shop needs work
    By kmstool in forum Employment Opportunity
    Last Post: 10-28-2006, 09:25 PM
  5. New Shop Looking for Work
    By DFeeney in forum Employment Opportunity
    Last Post: 10-28-2006, 02:00 AM
