585,996 active members*
4,691 visitors online*
    Jan 2010
    20
    Soft limit problem Mach3
    Hello I am having trouble turning on my soft limits, when I press the button under the DRO, I just get an error saying Machine out of limits for softlimit activation!! I have attached a screen set of my soft limit setup and main screen. I am wondering what the zero 4 is for and the reason that it is not working is that it is not deactivated or removed. Please tell me what to do!!!!
    Mar 2011
    584
    Try flipping the soft min and soft max values on the Z axis.
    Jan 2010
    20
    Worked like a charm, Thank you Cery much!
    Re: Soft limit problem Mach3
    Quote Originally Posted by vtx1029 View Post
    Wish you a good day ,
    I have the same problem URL= https://drive.google.com/open?id=1YU...F3lVplqR5jOw9w
    and i get the massage : machine out of limits for softlimit activation
    i try to change the z limits but i still have the same problem .
    please help me if you can
    thanks
    jeries facouseh
  1. x axis soft limit switch
    By barryhammers in forum Fanuc
    Last Post: 10-26-2015, 10:07 PM
  2. soft limit alarm
    By bigbobr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2012, 04:55 PM
  3. Soft Limit Confusion
    By Deviant in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2011, 09:16 AM
  4. syil soft limit settings
    By Matty T in forum Syil Products
    Last Post: 03-21-2008, 03:51 PM
  5. Mach3 limit switch problem on Ref Home
    By originator in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2006, 03:02 PM
