Large blocks of code
Be carefull if you Mirror your tool paths in NX. The cut direction changes from climb mill to conventional. If your cutting wood this may not be a problem but if you plan on using cutter compensation you will get undesired results on the mirrored paths.
I will mirror the path as a copy instead of an instance then I can "lie" to the system and change the cut direction from climb mill to conventional and the mirroring will reverse the direction. Still something thay need to fix IMHO.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
