585,906 active members*
3,739 visitors online*
Thread: MDF Madness
Page 3 of 20 1234513
Results 41 to 60 of 381
  1. #41
    Nov 2006
    11
    Quote Originally Posted by r00t4rd3d View Post
    Isn't that mount to large, the Dewalt is only 2.5" in diameter if I remember, that's over 3"
  2. #42
    Nov 2006
    11
    It's 2.715" Measured mine. I'll probably make something up in solidworks and make my own.
  3. #43
    Mar 2012
    276
    I guess the K2 Bosh Colt Mount would work.
    This colt mount should work also:
    http://www.zenbotcnc.com/mounts
  4. #44
    Mar 2012
    276
    Messing around with Microcarve. I am going to buy this app I think.
  5. #45
    Dec 2008
    292
    I use MicroCarve V4 quite a bit, it is a great little program. No frills, good basic functionality. I have made some great lithophanes with it as well as Celtic carvings.
    Don
  6. #46
    Mar 2012
    276
    Quote Originally Posted by atwooddon View Post
    Don
    What kind of bit sizes and shapes are you using with Microcarve? I just got some 1/16" bits, http://i.imgur.com/p4sUH.jpg , and they have been working the best so far.
  7. #47
    Nov 2006
    1036
    [ATTACH][/ATTACH]
    Are those fishtail bits? If so you can do even better with ball-nose bits with a stepover of 7-9% of the cutter width.
    First picture is the one you linked to, the second is ball-nosed bits from PreciseBits.com
  8. #48
    Dec 2008
    292
    I usually do a roughing pass with 1/8" ball nose and 15-20% stepover then a finishing pass with a 1/16" ball nose with a 7-10% step over. This works well generally but if you want to go super fine detail you can go to a small/narrow V carve bit with a 5-10% step over and the detail can amazing. Just remember, the machining time with the v bit and narrow point, small stepover can be pretty long. Results are spectacular on lithophanes, you can do small lithophanes (2x3") with tremendous detail..... Most of my stuff is done with a 1/16" ball nose, sometimes a 1/32" ball nose. Material is typically corian.
    Don
  9. #49
    Mar 2012
    276
    My first part, a router mount. Its wrong as I only know how to use PyCam to do engraving(Gravure) at the moment and it traced the line instead of cutting out the outline but its a step in the right direction.
  10. #50
    Mar 2012
    276
    Fixed!
    I found this mount design on here somewhere. The compression tabs were really thin for wood so I fattened them up some. Anyone else needs a wood mount for a Dewalt DWP611, the DXF is attached below.
    Attached Files Attached Files
  11. #51
    Mar 2012
    276
    The MDF has met its end, Oak.
  12. #52
    Nov 2006
    1036
    Are you going to remake your router with oak?
    If so, I have a few suggestions.
    First I'd use baltic birch plywood, or bamboo plywood because they are much more dimensionally stable than oak (and strong in all directions.)
    Second, if I was going to use oak, I'd make all my critical pieces, especially the risers go with the grain of the oak. If I understand what you have laid out, your risers might fail due to a crack along the grain. (edit, after looking more closely at your picture, it appears that is oak plywood not solid oak. correct?)
    Third, if I did use plywood, I'd still pay attention the the face grain. In many cases the long axis of the face grain is more resistant to bending than the across the grain.
  13. #53
    Jul 2012
    Do you fit stepper motor 3A
  14. #54
    Jul 2012
  15. #55
    Mar 2012
    276
    Its Oak plywood and after I cut out my pieces they will get a coat of Minwax Wood Hardener on them just in case
  16. #56
    Mar 2012
    276
    Started.
  17. #57
    Mar 2012
    276
    So I am carving along when all of a sudden.......
  18. #58
    Jul 2010
    1183
    I'd heard about a batch of chinese motors a few years ago that
    had that exact same problem. I hope there's not more of them to come.
    The problem was bad welds of the shaft to the motor rotor. I'd always assumed
    before that that the shaft was all the way through the rotor, so I
    was surprised to find out they weld them.
    Also, some assumed it was due to solid straight couplings. Which isn't
    exactly true. It was just bad welds, pure and simple. No shaft should
    crack off so easily on any motor of any sort. I've used solid couplings
    in the thousands and never have seen a cracked off motor shaft....and
    I've seen some serious mistakes on some of my machines.
    Sorry to see that....
    John
  19. #59
    Apr 2007
    8082
    It has happened to me on a 380 oz motor also, and it had a Delrin coupler from DumpsterCNC on the shaft. The weld is a fused joint from not high enough current applied. There is only a small pit slightly off center that was holding the shafts together.
    CarveOne
    http://www.carveonecncwoodcraft.com
  20. #60
    Mar 2012
    276
    Quote Originally Posted by CarveOne View Post
    I also had a non-flexable DumpsterCNC coupler on. When my new motor gets here it will be getting a flex coupler.
  1. Jogdial Madness
    By MacMarty in forum Tormach Personal CNC Mill
    Last Post: 04-28-2011, 04:28 PM
  2. Mopar Madness !
    By wilstyx in forum Employment Opportunity
    Last Post: 02-22-2011, 05:07 PM
  3. Mach3 and MPG2 madness.
    By cjdavis618 in forum Mach Software (ArtSoft software)
    Last Post: 07-25-2010, 05:58 PM
  4. Replies: 12
    Last Post: 08-06-2009, 03:19 PM
  5. CNC Madness (Restoring old parts)
    By samualt in forum Community Club House
    Last Post: 06-20-2004, 03:04 AM
