585,902 active members*
4,316 visitors online*
Results 1 to 11 of 11
    Nov 2011
    PROBLEM WITH 40W CO2 POWER SUPLY
    hello
    I had a problem with the PSU for the machine DC-K40
    I ordered a new unit, I got this:
    This is a power supply that was in the machine and broke down:
    I now have the wires that I do not know where to connect:
    anyone can help me with this problem?
    Thanks and regards ...
    :cheers:
    I may well be wrong but I *think* you have the wrong type of replacement, the new one is a *lasercut* type supply and the old one isn't?
    (PWM etc etc)
    Like I said I may well be wrong but I don't think that replacement will work with the machine you have (going by the picture of your existing PSU)
    best wishes
    Dave
    Nov 2011
    I hope you make mistakes
    I'm still ****ing Chinese sent a picture of power unit, and he sent me a second ...
    Aug 2012
    Quote Originally Posted by Bekir_SA View Post
    I have exactly the same problem. Can you help me? Which object they have sent to you? Where can I buy it? Needs some changes or are exactly the same plug?
    Try to get a manual or datasheet from en.Shenhuilaser.com about this supply especially the connections. (mail them?)
    Maybe it is quite simple to connect a more common (maybe better) supply to those wires. Maybe you only need a little extra hardware like an inverter or linedriver..
    What is your controllerboard BTW?
    If you can find data from that, it's fine too...
    Kees
    Aug 2012
    i want to find the -powersupply-exactly the same as the machine's because i don t know anything more about this..i have sent message at the company that you told me but they didn t give me more informations even if they sell this product they don t give me an answer how can i buy it...please if anybody knows where can i find the 40w powersupply it would be a big help for me....!!thanks for the moment...!!
    Oct 2007
    385
    Maybe this document will help you to make the supply work for you.
    40W+laser+PSU.pdf
    Milt
    Nov 2011
    I solved this problem ...
    Thanks anyway ...
    Machine runs better than ever ...
    Mar 2010
    dear friend,
    can you post how did you connected existing cables to new power supply ? even pictures would be fine. I have exact same machine and same cables
    also I saw that there's uc2825 (high speed) pwm controller on original power supply. I wonder if power controller (your first and original power supply) can be driven directly by pwm signal... that's what I try to learn from connection of original wires to your new power supply (boxed power supplies have connection names).
    thanks..
    Sep 2005
    55
    What do you step in the power supply?
    Nov 2012
    Help
    Please help, I have the same problem? If it works? Ask you a few hints, tips can attach a picture as possible [email protected].
  1. Power problem perhaps
    By thesaurian in forum Mori Seiki lathes
    Last Post: 01-31-2011, 04:45 PM
  2. Unregulated power suply
    By zeed in forum CNC Machine Related Electronics
    Last Post: 12-29-2010, 10:00 PM
  3. Z axis problem when power on
    By dung_ninhbinh in forum Fanuc
    Last Post: 08-18-2010, 07:03 AM
  4. Tri-power minor problem
    By bherr in forum Shopmaster/Shoptask
    Last Post: 05-19-2006, 01:21 PM
  5. Power Suply fun!
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 04-17-2006, 03:27 AM
