how can I copy okuma g-code programs formatted in osp and to a windows pc and view and edit them?
send them out to a PC using RS232 or floppy in DOS mode then simply edit them with any common text editor.
I have okuma osp programs saved to 3.5 floppy I am trying to copy them to a pc and view and edit them how can I do that? The pc will not reconize the disk when I insert it into the drive.
use this program attached to read OSP floppy on PC and copy to PC directory.
it's a little bit quirky but it does work.
There was a web page for it but the page is dead now so see attached.
this is the thread here if you want to read about it....
http://www.cnczone.com/forums/okuma/...simulator.html
Fordave11
Can you repost Version 1.98 as your post is V 1.93
no. I dont have it. the old version is enough for transferring okuma floppy files to PC
thank you
