Originally Posted by
LordThrash
Hi, Ive been tracking down a bridgeport mill for my shop. Plan on going 3 axis CNC with mach3, geko drives, breakout board servo setup.
I recommend getting going with the minimum of effort and expenditure. You say the machine still works, so all you need is Mach3, a Hillbilly B.O.B., and a computer. You can use the existing drivers and motors.
Changing the machine from steppers to servos is a royal PITA! You will need to make adapters for the motor mounts and figure out how to get the timing belt pulleys to fit on the shafts. The original motors are 5/8" shafts and are longer than most. You will have a real challenge finding a way to reliably extent the shafts of any motor you end up with.
If you are dead set on a servo system, you should get a machine already set up that way. The later BOSS machines had servos. Otherwise, use the steppers to get going and you'll likely never go to servos. Steppers work just fine!
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
