585,974 active members*
4,286 visitors online*
Results 1 to 6 of 6
    Oct 2010
    68
    RC filter networks
    First of all, let me say that my knowledge of and experience with electronics is very limited. I'm a CNC setup guy who often times needs to fix machines. I'm hoping someone with experience here can help with my problem.
    Background:
    Hardinge CHNC I lathe with Fanuc OT-B controller has been giving intermittent alarms: 930 CPU Interrupt or RAM (or ROM... I don't remember) Parity Error. Usually, I can shut down the machine, power up, and everything's fine. Sometimes, though, I need to clear the memory and reload all parameters, programs, offsets, etc. These alarms can happen a couple times a day, or I can go a few days without one. They always happen in the same part of the program, though. It's always during a collet open or collet close. The collet actuator is pneumatic which is controlled by a solenoid which is controlled by a relay. So, this tells me that I'm getting some sort of electrical interference from either the relays or the solenoid. I've tried swapping relays and replacing relays, but that hasn't worked.
    A friend of mine suggested that I install an RC filter network on the suspect devices. Does this sound right? I had no idea what those were, so I tried doing some research, and learned a little, but not enough to figure out how to do it.
    My question is where to install the RC filter network? across the coil of the relay? across the contacts of the relay? across the coil of the solenoid? I also don't understand how to specify the RC filter network. How do I determine the R and C values?
    Thanks in advance for your help. I really look forward to getting this annoying problem fixed.
    Robert
    24221
    The RC snubber is usually fitted to AC coils and solenoids, .22µf with 100ohm in series.
    Do a search for snubber here and should pull a few links up.
    If the coil is DC you need a reverse EMF (reverse biased) diode across the coil itself.
    Always fit as close to the coil as possible.
    Al.
    Albert E.
    Oct 2010
    68
    The relay coils are DC. When I replaced the relays, I got ones of the same type, but with the "surge suppression diode" option. Is this the reverse-based diode you mention?
    24221
    Sounds like they are already fitted, when using these types you need to make sure how they are polarized in order to hook them up the correct way.
    Al.
    Albert E.
    Oct 2010
    68
    The relays are the plug-in type. They're IDEC RH2B-UD DC24V. Maybe I don't understand, but I don't see how they could be hooked up the wrong way. So, if my relay coils already have the diode suppression, what else could be causing my problem?
    24221
    Im not saying they are hooked up wrong, just that if they are a new installation and the polarity is not observed you blow a P.S. fuse.
    Make sure that the solenoids also have a snubber, if AC and a diode if DC.
    Al.
    Albert E.
  1. Why do I need Input filter?
    By tome9999 in forum CNC Machine Related Electronics
    Last Post: 01-23-2012, 07:26 PM
  2. arc filter
    By 60rock in forum Mastercam
    Last Post: 09-01-2011, 07:22 PM
  3. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  4. DOS TCP/IP for Microsoft Networks
    By scratch_6057 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-11-2008, 08:23 PM
  5. DOS TCP/IP Bootdisk For Microsoft Networks
    By scratch_6057 in forum Computers / Desktops / Networking
    Last Post: 04-09-2006, 12:41 AM
