585,581 active members*
4,020 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > how to remove backlash in knee drive bevel gears
Results 1 to 2 of 2
    Mar 2012
    378
    My Bridgeport has probably ten thousandths backlash in the bevel gears from the knee drive handle to the lead screw. Aside from replacing the gears with new ones is there any way to adjust out some of that play? Do I need to remove the gears and put in shims or is there some type of other adjustment mechanism? I don't have the machine taken apart yet so it is very difficult for me to see what there is to work with right now.
    May 2004
    4519
    They need to be shimmed closer together for tighter engagement.
  1. Air Assisted Knee Backlash on Series 2
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2012, 06:35 AM
  2. How do you remove knee of series 1 mill
    By cruzin in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2010, 10:08 PM
  3. Can you make Bevel Gears??
    By sleepy23 in forum Employment Opportunity
    Last Post: 04-29-2010, 01:39 AM
  4. Eliminating backlash with worm gears
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 01-27-2006, 03:17 PM
  5. Delrin spur and bevel gears
    By Crazy Phantom in forum Employment Opportunity
    Last Post: 01-15-2006, 06:04 AM
