585,763 active members*
4,191 visitors online*
    Feb 2009
    6028
    Mach 3 decimal place.
    Looking at using Mach on a couple potential retrofits here.
    First one (test bed) is just a 3 axis bed mill. Leaning towards the AJAX back end right now. This machine, .0001" is fine for resolution, the next possible one is a lathe, just 2 axis, but will need .00001" resolution on this one. Can Mach be configured for that? And yes I understand I need a motion control system to handle that, and temp control. Thats all in place already.
    How about the "brains" in the mach? Can this handle lube pump timers with low pressure alarms and low float level alarms? Ive done ladder work on industrial controls, this looks very different. Can it be used to lets say interlock a spindle if the brake is on?
    And lastly for now, is there any better screen sets? the one it comes with looks kinda cartoonish.
    Thanks all.
    Feb 2009
    6028
    Any one?
    To get more decimal places, you need to edit each DRO in a screen editor. It's pretty simple to do.
    I think the Brains will do what you want, but haven't tried it, so can't be sure.
    Everything I've read says that support from Ajax is terrible. You might want to look into that. There are threads here and the machsupport forum.
    More screens here. ArtSoft USA - Screensets
  1. Mastercam X, force 4 decimal place output
    By critz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-28-2020, 06:41 PM
  2. How to prepare a FADAL 3060 to transport form place to place
    By Swykore in forum CNC Machining Centers
    Last Post: 08-08-2011, 01:09 PM
  3. decimal points
    By zarl in forum MetalWork Discussion
    Last Post: 06-08-2009, 05:30 PM
  4. need 5 decimal places
    By kendo in forum Haas Mills
    Last Post: 04-13-2009, 06:43 PM
  5. OM-D decimal place limits
    By meadowtech in forum Fanuc
    Last Post: 02-20-2009, 08:36 AM
