585,665 active members*
3,813 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > What is your Favorite 3D CAD Program
View Poll Results: What is your favorite 3D CAD software
Voters
647. You may not vote on this poll
  • Solidworks
    369 57.03%
  • Alibre Design
    46 7.11%
  • Inventor
    94 14.53%
  • Sketchup
    59 9.12%
  • Rhino 3D
    75 11.59%
  • Ashlar Vellum
    4 0.62%
Page 1 of 5 123
Results 1 to 20 of 93
    Aug 2003
    329
    What is your favorite 3D CAD software and why.
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Feb 2010
    371
    You need to add SpaceClaim to the list. Great software and very easy to use.
    Aug 2003
    329
    Quote Originally Posted by AiR_GuNNeR View Post
    Thanks for the info. The survey only allows six entries. Maybe I should ask what folk recommend in addition to the other cads.
    Bill
    AutoCAD.
    Because I'm faster with it than anything else.
    673
    The question is not that simple. From a professional standpoint, you need to look at the total art-to-part cost and efficiency. On the CAD side, Inventor was awesome to learn on, but not very stable, so after some years I moved to Solidworks which I really like, but getting my 3d model to a cuttable part is a total PITA. May as well just do in autocad and dump to master cam or just use master cam end-to-end... That said, I still do my full design in solid works, then spend way too much time re-doing and editing g-code in master cam, finally tweaking in NC (Mach3)
    I'd like to find an affordable integrated cam solution that works out of the box with solid works that doesn't totally suck - Most are either way more than I need, or missing basic functionality. If I could find a good solution, then I'd be a happy camper.
    May 2003
    162
    For me, parametrics or not, Rhinoceros is the fastest.
    Pro Engineer not on the list...?
    1943
    Catia?
    Aug 2003
    329
    The survey only accepts 6 fields. If you favorite cad is not included just make a post and it will be counted at the end of the poll. If enough people mention a brand it will get compared as well.
    Feb 2012
    Keycreator/CadKey
    Aug 2010
    14
    SolidWorks
    Apr 2012
    19
    Microsoft Word
    Nov 2010
    Cabinetvision
    Cabinetvision is good enough for me!
    May 2012
    7
    Old Pro-E Version 15
    It is like having a personal drill sergeant assisting me to exercise my brain.
    Jun 2004
    8
    Nov 2011
    107
    Solidworks rules!!!
    Enviado desde mi Transformer Prime TF201 usando Tapatalk 2
    Jun 2007
    180
    Started in DOS version of Cadkey many years ago creating 3D drawings then moved up/upgraded over time to the latest version of KeyCreator with the ad-on KeyMachinist. I can now draw a 3D solid and then create the toolpath, then simulate the toolpath all on the same screen in the KeyCreator Cad program and then send the g-code to my machine using the editable post processors. Very user friendly and don't have to go from one program to another for Cad/Cam. :cheers:
    Add Cadkey/KeyCreator to the list. :stickpoke
    Aug 2003
    329
    Wow there seems to be a lot of Solidworks fans. What is it about Solidworks that makes you like it so much? I'm really curious.
    Bill
    Mar 2008
    161
    Should have just had an "Other" Catagory :P
    Personally, I really like my BobCad V22. I could afford it and it has paid for itself many times over. Simple learning curve too.
    Oct 2010
    solvespace
    I really solvespace, it's free, small (981kb!) and parametric.
Page 1 of 5 123
  1. Your Favorite Material
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2013, 03:23 PM
  2. Favorite Mods
    By doanwannapickle in forum Taig Mills / Lathes
    Last Post: 09-13-2009, 11:09 PM
  3. Today's favorite line drawing to g-code program
    By IQChallenged in forum G-Code Programing
    Last Post: 12-27-2007, 07:57 PM
  4. Favorite G offset?
    By Trapper14 in forum G-Code Programing
    Last Post: 08-14-2006, 03:02 PM
  5. What is you favorite printer?
    By cncadmin in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-25-2005, 03:21 AM
