Does anyone here in the USA use ProNC Communication Software to remotely transfer EIA programs?
I prefer Cable, because too much interfee..... with remote. Nice future but not recommend.
It looks like it is cable....???? Not much "future" about it. Multiple DNC systems have been around awhile. Predator, Ascendent,... etc. Looks like a nice system though. Been using wireless systems for awhile too. No problems.I prefer Cable, because
It's just a part..... cutter still goes round and round....
We do remote file callups for both EIA and Mazatrol CMT files with our PC-DNC Plus software, so I know it works. I'm not sure why your ProNC software doesn't work because I've never used it.
Can you send a file to the DNC system from the Mazak? If you can, (but you can't send one back), you're probably not sending the data in the correct format. Mazaks need that "%" at the beginning and end of the file. If you can't send files either way, double check to be sure that your baudrate and stop-bits settings are the same on the Mazak and on the DNC system.
