585,992 active members*
5,292 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > PC PARAMETER LIST FOR 6M FANUC DRILL AND TAPE MACHINE
    Jul 2010
    Hi
    I am looking for PC PARAMETER list for FANUC CNC MILL MACHINE specification MACHINE TYPE - A04B-0034-A003
    SERIAL NO. D-530408 DATE 1985-1
    Even i don't know what is machine name . model ? etc...
    If you have similar machine please send me PC PARAMETER . that parameter only view by following process
    press parameter button see the screen for PC PARAMETER
    then press N 1000 AND PRESS INPUT
    then you can see parameter number 1000 , and scroll down to get next parameter . same process for parameter 2000, 30000 and 4000
    I will pay for this help as you wish ,
    contact through email [email protected]
    thanks
    Jun 2008
    This is FANUC tape center Model D machine. Open the electrical panel and send the PCB and drive details, Motor specification (A06B-XXXX-XXXX). Also check you got any circuit diagram, Parameter list, Datasheet or any manual with the machine
    Sep 2010
    125
    did you found your parameters ?
    and if not, just tell me if your fanuc is a 6Ma or 6Mb ? (parameters from 0 to 164 or 420 ?)
  1. Fanuc 5M parameter tape??
    By fluffyflex in forum Fanuc
    Last Post: 10-23-2021, 04:18 AM
  2. fanuc tape cut-mate parameter lost
    By aidinjoon in forum Fanuc
    Last Post: 06-08-2021, 07:44 PM
  3. Fanuc FV Tape Drill
    By brakmaren in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2009, 02:40 PM
  4. Fanuc 12M parameter list
    By duccnc in forum Fanuc
    Last Post: 07-28-2008, 07:20 AM
  5. help with fanuc 18i parameter list
    By bob1371 in forum Fanuc
    Last Post: 11-06-2003, 03:24 PM
