Originally Posted by
txcncman
Until you have machined more than one-half of the sphere, you do not have anything to reliably hold onto to machine the opposite side. I would use CAD/CAM and create a solid model. I would start with a piece of square bar stock vertically in a vise. I would machine approximately 1/3 of the diameter depth with a ball mill. Then I would lay it down on one of the flats and machine the center 1/3 of the diameter, turning 90 degrees each time. Then, holding on the ball itself at just over 1/2 diameter, I would mill off the remaining stock material and finish the last 1/3 of the ball.
