585,973 active members*
4,218 visitors online*
    Dec 2010
    torq cut 22 bridgeport
    At startup I usually get alarm message"axis drive fault". After it is reset the machine usually works fine. Now alarm comes up every time. Motors,drives. voltages all look OK. Can't pinpoint the problem. Just thought I'd post this incase someone can help. looking for repair advice or technition's service manual. thanks.
    Nov 2004
    164
    Are all of your drives the same? Can you swap two of them and see if the problem follows the drive board or is the problem isolated to a particular axis/motor/wiring.
    I had a drive board give me intermittent problems and found a cold solder joint in the pcboard terminals that were going out to the motor. A five minute fix with a soldering iron made it go away permanently.
    Nov 2004
    3028
    You do not know what is causing the problem, do you. Meaning which axis.
    Go to the maintenance page, press 0 for more commands, press 3 to select a item to watch in the diagnostic, select par 153.
    When it faults, it will display eight digits. One will be a 1 which is where the fault is.
    Example: 10000000 is a X fault while 00010000 is a spindle drive fault. If a spindle drive fault, press in contactor 3 which will turn on the spindle drive and you can see if a fault is displayed.
    Side note: this machine has DC servo motors that have brushes. Per Bridgeport, the are to overhauled every 4000 hours of operation. Another note, the x and y motor are the same. The Z is much bigger with a higher capacity drive.
    George
    Jun 2012
    I am having the same problem but when I look a param. 153 it does nothing.Also my voltages are a little high#2 and # 50 should be 132 and is @148
  1. Bridgeport Torq-Cut TC 3G??
    By Kristjan in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2017, 11:47 AM
  2. Bridgeport Torq Cut 22 HELP PLEASE!!
    By groovemixer in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2010, 05:54 PM
  3. Bridgeport Torq Cut 30
    By charliemisa in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2010, 12:11 PM
  4. Bridgeport Torq-Cut 2G-?????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 10-21-2006, 06:56 AM
  5. Bridgeport Torq Cut 22: What lubricants? Where? How?
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 06-24-2006, 07:38 PM
