585,758 active members*
4,402 visitors online*
Results 1 to 6 of 6
    Feb 2012
    Lightbulb 3 axis lathe with live tooling
    We are in the market for a 3 axis lathe with live tooling. Maybe one with tapered tool holders and a tool changer. Does anybody have any recommendations as far as what we should be looking for? I have personally set-up only one of these in my 24 years as a cnc guy. It was a Hitachi-Seiki. It was quite an impressive machine. The owner here wants to go with a Miyano. I'm looking for comments and suggestions...
    Oct 2007
    6
    Well that depends on a few things. The diameter of workpieces. Is quality and reliability a higher priority than production speed?
    Miyano lathes are suitable for larger batches because it takes time to rigg them.
    As a Miyano-enthusiast in Sweden, I'd highly recommend Miyano-machines.
    Feb 2012
    Our work will be primarily collet work. 2.0" and under in dia. Mostly under an inch. We will use a 12" barfeeder and run high quantities of threaded parts with tight tolerances. Our thread minors and majors on our unique threads, are +\-.001" for example. And there are shoulders, depths, and hole patterns are tight also. The parts we are buying this machine for are high quantity... though we have a good deal of short, prototype runs also, so no doubt we will use machine for this, as well as the occasional chuck job. We make cutting tools out of hss (M2) also, so we will need an accurate, repeatable machine that can hold tolerances, and won't be too big of a pain in the butt to set-up
    Aug 2010
    156
    ahhhh i miss my Hitachi's
    Both ...Mori and Nakamoura make a good lathe and still stick with Fanuc.
    Stay away from any control that is unique to a builder or type of machine.
    Oct 2007
    6
    If you could send me a crude drawing(if its sensitive) of the part I'd gladly recommend a machine.
    Feb 2009
    6028
    Mori Seiki has the best live tooling set up IMO right now on a medium sized lathe.
    Doesn't really matter what you go with as long as YOU HAVE GOOD SUPPORT IN YOUR AREA! Thats critical. And stay away from odd ball controls.
  1. Programming a flat with live tooling and c axis on a lathe
    By surfit in forum MetalWork Discussion
    Last Post: 06-16-2017, 10:12 PM
  2. CNC Lathe w live tooling??
    By cloud chaser in forum RFQ (Request for Quote)
    Last Post: 07-09-2011, 04:17 AM
  3. Lathe with live tooling
    By baldysm in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 05:28 AM
  4. live tooling, c-axis.. lathe or mill
    By krazatchu in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2007, 02:51 PM
  5. Adding 3rd axis/live tooling to lathe
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2005, 02:40 PM
