585,764 active members*
4,005 visitors online*
Results 1 to 6 of 6
    May 2012
    problem engraving
    I have an American laser Explorer. I have problems with engraving - an inscription is not clear, cursive letters. In the file when I have two colors / Cutting Drawing / eg red, green does not go as the project is to move a few millimeters to the left or right. Never in the vertical only moves horizontally. What could be causing this?
    Aug 2003
    494
    Check for loose belts or loose pulleys. Also check the belts to see if they have broken tension strands inside them.
    I am not completely useless.......I can always serve as a BAD example.
    pls check the Focus distance and the Laser Power and the Laser Speed you set in the software.
    Abby
    G.Weike Laser
    [email protected]
    [email protected]
    Skype:abbylilu
    laser engraving machine?laser cutting machine?cutting plotter at G.WeiKe
    Nov 2010
    787
    Quote Originally Posted by G.Weike-Abby View Post
    CNC lasers, constructions, service
    Sep 2011
    58
    Question about letter not clear
    Hi
    It has relationship with Software Technical Data Setting or Configurations of machine.
    What kind of software, driver of your machine? Is it Newlydraw? And, is X aix idler wheel to transmission?
    Will you please send us Reference Picture? Please email me, we'd like to guide you how to solve it.
    My email: [email protected] MSN: [email protected]
    Lucy Mob.: 0086-18254116182
    Jinan Quanxing Mechanical Equipment Co.,Ltd
    Lucy (Jinan Consure Electronic Technology Co.,Ltd) 0086-18254116182
    Web:http://www.jncslaser.com Email: [email protected] Skype:consurelaser
    Mar 2012
    We had the same problem for a while: the issue was that we were cutting in the absolute upper-right corner (near the laser's "home" position when it started), and I think we had the settings a bit weird on the software. It would "correct" itself by a few mm each time it ran.
    When we started doing items in the center of the table, this "resolved." I don't know that we ever actually found the issue, but it was amazingly frustrating, and simply changing the workspace location fixed it.
    -MJD
  1. LS3020 ENGRAVING PROBLEM.
    By ru-alright in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2011, 11:46 AM
  2. Engraving Problem
    By g1r9a6d8y in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-08-2011, 04:43 PM
  3. PROBLEM ENGRAVING
    By REM in forum Mastercam
    Last Post: 11-04-2010, 12:20 AM
  4. glass engraving problem
    By loyedp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2010, 10:49 AM
  5. laser engraving problem
    By fish09 in forum Engraving Machines
    Last Post: 02-04-2010, 02:02 AM
