Hello,
Just one question .
I'm designing my gantry router these days .
It wil mainly be used as a wood router for gutar parts .
Cutting speed is not the most important thing for me.
Over the last year I got lots of linear components toghether, so now I only have to put everything in the right place .
I have a starlinear (bosch rexroth ) rail of 1036mm long in the 30 mm size and two carriages ( 1653-794-20 ) .
I was thinking of using only one rail for the y axis on the gantry .(maybe with two carriages in line about 240mm long together).
I planned on screwing the rail on a 100mm square iron tube (thick walled)and use a leadscrew on the top of that tube to move the y axis so there will be a sort of L saped connection between the carriage and the leadscrew nut support.
The specs of this rail and carriage seem quite heavy and strong so I thought it would be ok to use one rail only for putting on a Z axis mechanism (not too heavy )and a 1 1/2 hp router motor .
The Z axis movement will be about 4 inches .
Thanks for reading this post .
Paul Belgrado
Belgium
