585,981 active members*
4,156 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Toolgrinding / Toolgrinding Machines > Electroplated Diamond Wheel Vs. Resin Bond Diamond Wheel
    Apr 2006
    225
    Question Electroplated Diamond Wheel Vs. Resin Bond Diamond Wheel
    Hi guys,
    Whats the difference between those 2 types of grinding wheels? The only thing I have noticed is that the Hard electroplated ones have steel disks and the resin bond most of the times are aluminium disks ( cools better? )
    I use it to grind carbide tools, I use the cup shape ones and they are available in both types. Is there any of this 2 that is better for my application? Witch one lasts longer? Any pros and cons?
    Their price is the same
    Gustavo
    Oct 2012
    only pros I know of for the plated are you can get them made to shapes that you can not dress on a wheel dressing machine....the downside is if you need them redressed you have to send them back to the manufacturer....the bonded wheels last much longer because you can redress the shape back into it over and over and true it to the arbor....I have tried every cup on the market and hands down its 3m cup wheels that get my vote.
    Apr 2006
    225
    Thanks for the info. I ended up buyng a electroplated... Well now that I know next one I buy a resin bonded.
    Thank you
  1. diamond turning
    By gits in forum Glass, Plastic and Stone
    Last Post: 10-26-2011, 05:07 AM
  2. Abrasives: CBN is not Diamond!
    By widgitmaster in forum MetalWork Discussion
    Last Post: 09-01-2010, 12:40 PM
  3. Sharpening carbide with diamond wheel
    By Vern Smith in forum Toolgrinding / Toolgrinding Machines
    Last Post: 07-08-2010, 05:14 AM
  4. diamond pin
    By fpworks in forum MetalWork Discussion
    Last Post: 09-18-2006, 05:52 PM
  5. Surface Grinder Wheel - Diamond Dresser question?
    Last Post: 06-27-2006, 06:00 AM
