585,933 active members*
3,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Rigid tapping tooling, and drill tooling
    Aug 2008
    132
    Hello again...
    I am making some investments into some tooling components for my 4020HT machine (CNC88HS) 1995. Among investing into some Chick vises and base plate, I need to really look at using my rigid tapping function... I have a few things to work out on my posts (using HSMWorks) - but thats for another day.
    For now, I am looking for guidance in what actual taps and holder to purchase for rigid tapping steel (A36, 1018, etc) and aluminum...
    Looking for good quality taps and drills....carbide tipped drills, etc - something for general purpose work... I am not a job shop, I mainly do custom parts for robotic end of arm tooling - but nothing sucks worse than a melted drill bit or broken tap....
    Any suggestions on manufacturer and type of drill bits and taps?
    Thanks!!! :drowning:
    May 2004
    4519
    Don't be cheap. There is not one brand that outshines them all, in my opinion. Get drills and taps in the middle price range and you should be ok.
    What is most important about drilling and tapping is doing it with the best techniques. Learn when to use spiral point, spiral flute, and forming taps.
    Apr 2005
    1194
    You dont need to buy more than you need or you will see that capital sitting there in a useless holder or tap.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    May 2005
    53
    We have had good luck holding taps in nothing more than ER collets. As far as tap styles- name brand spiral pointed taps for through holes and spiral fluted taps for blind holes in stringy material. Jobber drills work fine for 99% of what we do. I suppose if you had a production job in a difficult material it might justify purchasing high performance drills or taps.
    Hope this all helps.
    Techman
    Jan 2004
    3154
    Yep - what they said.
    Melted drills are a sign of very wrong feeds and speeds.
    www.integratedmechanical.ca
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Rigid Tapping in live tooling
    By JScharp 7675 in forum Fanuc
    Last Post: 02-01-2011, 12:40 PM
  3. rigid tap with live tooling?
    By dahui in forum Haas Lathes
    Last Post: 01-14-2008, 06:04 AM
  4. vmc tapping,tooling
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 11-15-2006, 12:07 PM
  5. Cat30 tooling in BP rigid ram problem
    By MrWild in forum Bridgeport / Hardinge Mills
    Last Post: 07-20-2006, 07:59 PM
