585,885 active members*
6,430 visitors online*
    Nov 2009
    26
    DM4400 Questions
    I may be going to look at a DM4400 this weekend.
    What is the approximate weight of the machine?
    What are the approximate dimensions, L X W X H?
    Does the machine use ball screws or acme?
    Any info will be appreciated!
    Rex
    Oct 2005
    672
    DM4400 or DM4400M?
    Mechanically the same but the DM4400 uses Dyna's SKIP control with stepper motors while the DM4400M uses Mitsubishi control with servos. Both use ball screws.
    Machine weight is about 4500lbs or 2000kg.
    Nov 2009
    26
    Thanx for the reply, Caprirs.
    This machine has the Dyna control, I think, my friend said his friend (the owner) told him that programming it was, "nothing like a Fanuc".
    I didn't realize how heavy they are......I was thinking around 2500lbs.
    Rex
  1. DM4000 / DM4400 DM 2400 manuals
    By maddog1927 in forum Dyna Mechtronics
    Last Post: 09-10-2019, 08:53 PM
  2. DM4000 DM4400 manual
    By 2ferrous in forum Dyna Mechtronics
    Last Post: 07-04-2012, 05:44 PM
  3. DM4400 will not initialize
    Last Post: 08-23-2011, 12:48 PM
  4. Just got a DM4400
    Last Post: 08-24-2010, 02:27 AM
  5. DM4400 problem with turnovers spindle
    By gelos in forum Knee Vertical Mills
    Last Post: 10-24-2008, 08:16 PM
