585,974 active members*
4,304 visitors online*
Thread: Okuma LS oil
Results 1 to 8 of 8
    Jan 2009
    35
    Okuma LS oil
    Hello, I have a older Okuma Ls manual machine that i need a little help with. I believe they actually call it a LS-540mm by 1500mm. Im also not sure but i think its a 1964 model with a serial number of LS 4109-10352 but if anybody knows how to deciper the serial number that would be cool. I was looking to change the oil in it from when i got it but when i called around all i got was that it took 2.5 gallons of #90 turbine oil. When i called some oil distributors they didn't know what to say either and looked on the net all i coud find is that #90 turbine oil came in different viscosities. I looked at the old oil but its kind of dark to tell what it actually is or how thick it should be. All i have is the electrical manual for the machine so if somebody has a actual manual with some specs or done this before i would greatly appreciate it. Thanks, Andrew.
    Jan 2009
    74
    The oil is the same as CB32, so DTE oil light.
    fun fact, the serial number has the date code followed by the serial number, the 41 is year, expressed in the year of the emporer, so 1925 + 41 is the year 1966, and month is the 09, so September. the serial number would be 10352.
    Re: Okuma LS oil
    Quote Originally Posted by old timer okuma View Post
    I just bought Serial # 4109-10318 yesterday for $500. Guy didn't know what he had. I powered it up and it runs sweet. Head sounds good, nearly zero backlash. It's a good day.
    My machine doesn’t have the date code, just the serial number, I don’t see how you arrive at that for the date?
    Feb 2009
    6028
    If you got one in good shape, those things sure are nice. I remember running one that was about 20 years old at the time. Smooth as Japanese silk. I would take one of those over any other manual lathe in the day.
    Mar 2009
    1982
    Re: Okuma LS oil
    depends where you're looking at. Identificator is on the cast body, on the electrical cabinet and on the papers. OSP in case of CNC ... Just look for more numbers.
    Quote Originally Posted by Algirdas View Post
    I will have to keep searching, the only number I found was stamped on the tail stock end near the ways. I don't have any papers as this is an older LS.
    Inside the electrical cabinet?
    Mar 2009
    1982
    Re: Okuma LS oil
    Picture here?
  1. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  2. Replies: 2
    Last Post: 11-11-2010, 09:37 AM
  3. Okuma Howa Vs Okuma
    By gcrudgington in forum Okuma
    Last Post: 07-01-2010, 03:11 PM
  4. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
  5. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
