585,951 active members*
3,988 visitors online*
    Feb 2010
    17
    Sodick A280 - Floppy won't initialize
    This machine has a NEC PC9801UV computer and I am trying to initialize a floppy disk to copy system to it. When I select "user initialize" it says put disk in drive 2 and hit enter. I do that and nothing happens. The light on the floppy doesn't come on at all and the computer locks up. Also, none of the soft keys do anything. Is there something in the parameter lists that need to be set or changed?
    May 2012
    180
    Are you trying to make a system disk or user disk?
    Sent from my Sensation using Tapatalk 2
    Feb 2010
    17
    Thanks for the reply. On the "disk" screen there are 4 choices. User Format, User Copy, System Copy and System Version Update. I have tried all 4 choices and I cannot write to a new disk. If I select "User Copy" I can copy files from a user disk to another disk if the destination disk has been used. If the destination disk is new the computer doesn't even see it. If I select "User Format" and press enter absolutely nothing happens and the computer locks up. I thought maybe the computer had to "think" for a while but after 15 to 20 minutes it was still locked.
    May 2012
    180
    Think I have had same issue in the past, I think if you format the disks on your desktop first they then are readable on the mc. Not sure if its fat, or fat32. If your unsure check one that has already been used. Also check the disks. one side of disk will have the write protect hole the other side also has a hole, this needs to be covered. We use abit of insulating tape.
    Hope this helps!
    May 2018
    Did you figure out what was wrong? I'm having the same issue, formatting the disk on a pc doesnt work either
  1. Sodick A280 radius programing
    By rfarleman in forum EDM Discussion General Topics
    Last Post: 03-12-2020, 02:12 PM
  2. Floppy Controller card PCI floppy drive USB kit
    By logamuthu in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 05:23 PM
  3. Does any one using Floppy emulater for Sodick Wire EDM
    By Surjit in forum EDM Discussion General Topics
    Last Post: 09-20-2011, 11:21 PM
  4. Sodick A280 "heat stop by overload"
    Last Post: 02-07-2011, 05:12 PM
  5. sodick a280
    By jeromep in forum EDM Discussion General Topics
    Last Post: 02-18-2009, 10:40 PM
