Architecture Model Production Sample made by CNC router:
Material: ABS board 2mm
1.Put ABS board 2mm to CNC router table;
2. Engrave and Cut ABS board by CNC router as the program file. This program file can be created and edited by CAD or CorelDraw etc software, then transfered to Type3 or ArtCAM for getting G code file with tool path. This G code file can be read by CNC router control system, such as DSP hand controller or Weihong controller.
3.Now the whole piece of ABS board is cutted or engraved as the program file. Seperate them and then glue them together. May be you are curious of the architecture model with glass window. There is whole piece of acrylic glued inside of model. So you can see that the building model is with glass window.
