584,837 active members*
4,895 visitors online*
IndustryArena Forum > Hobby Projects > Wooden Clocks > Four foot wooden gear clock...advice please
View Poll Results: Which dial do you like the best?
Voters
25. You may not vote on this poll
  • Dial number one (no numbers)
    9 36.00%
  • Dial number two
    6 24.00%
  • Dial number three
    8 32.00%
  • Dial number four
    3 12.00%
Multiple Choice Poll.
Results 1 to 12 of 12
    Mar 2007
    19
    Hi Folks,
    About four months ago I set off to build a wooden gear clock based on Brian Law's Clock #7. I have most of the parts made, and I'm starting to put the clock together. The last piece that will be cut is the clock dial. I'm toying around with a few different designs, and I'd like to get folks opinion on what dial looks the best.
    The dial will be white, made out of Pine or Aspen, and the numbers or lines, will be cut separately, painted black, and inlayed in to the dial.
    Attached are some pictures, please let me know what you think...comments and suggestions welcome.
    Thanks,
    Shawn
    Attached Thumbnails Attached Thumbnails Clock-7-p2.jpg   clock-dial1.jpg   clock-dial2.jpg   clock-dial3.jpg
    Feb 2012
    Shy away from the norm and make the dial 'oval' in shape,that would make it look real good.
    Mar 2007
    19
    Like it!
    I like your thinking....I'm going to stew over that one tonight....and do some drafts tomorrow....like it!
    Quote Originally Posted by HorridHenry View Post
    Feb 2012
    Summat like this but as a chapter ring type face like the round ones you have posted ie nothing in the middle to reveal the works of the clock.
    Home 12.5-Inch Gold Pendulum Clock | Meijer.com
    Mar 2007
    19
    Yes, I see exactly what you're saying. Mostly transparent. Let me whip up a draft....thanks for the idea!
    Feb 2012
    I used to have a wooden clock once.....it wooden work though.
    Mar 2007
    19
    I've heard this before...hoping to have a normal heart beat by this weekend...hence the reason for holding off building the dial. :-)
    Feb 2010
    331
    i like 1 or 3
    May 2004
    162
    humor
    Dry English humor... I like it(nuts)
    Feb 2010
    331
    i would really like to see more pics of your build and the parts along the way (if you have them) i really want to build one of these, and would like to see more of yours.
    Apr 2011
    After first reading this thread a month or so back, I too got bit by the clock bug.
    I tackled Clock1 just to see if I could build one and make it run.
    I can report total success...
    The dial is only temporary. I plan on a much nicer dial later.
    I found his plans very will done and easy to follow.
    I plan on doing a couple more of his designs later for family and friends.
    Jun 2007
    3757
    Italic!! YUK
    Italic numerals look like they are falling over
    I have two clocks with this style, and depending where the hands are they look awful.
  1. looking for a cad diagram of a wooden clock
    By woodman08 in forum Wooden Clocks
    Last Post: 03-24-2019, 11:01 AM
  2. Wooden Clock Gears
    By wallyign in forum WoodWorking Topics
    Last Post: 04-18-2012, 04:43 PM
  3. Escape wheel for wooden gear clock
    By pinhead_mt in forum BobCad-Cam
    Last Post: 03-24-2012, 06:09 AM
  4. Adjusting time on a Wooden Clock
    By Mogal in forum WoodWorking Topics
    Last Post: 01-02-2012, 10:36 PM
  5. using cnc to make a wooden clock?
    By panofish in forum Benchtop Machines
    Last Post: 07-10-2008, 07:27 PM
